SG300-10 show lldp details causes reboot
ciscorobareed
Running the newest firmware available
$ show version
SW version    1.1.2.0 ( date  12-Nov-2011 time  23:34:26 )
Boot version    1.0.0.4 ( date  08-Apr-2010 time  16:37:57 )
HW version    V01
This is how I can cause the reboot to happen every time. Please advise.
$ show lldp neighbors GE 10
Device ID: <mac address>
Port ID: 22
Capabilities: Bridge
System Name: av-wwp
System description: LightningEdge (tm) LE-311 Access Concentrator
Port description: Fast Ethernet Port
Management Address: <ip address>
Time To Live: 96
802.3 MAC/PHY Configuration/Status
Auto-negotiation support: Supported
Auto-negotiation status: Enabled
Auto-negotiation Advertised Capabilities: 1000BASE-T full duplex
Operational MAU type: Unknown   <-- loose connection here and switch goes for a reboot.
Rob
David Hornstein
Level 7
Level 7
Hi rob,
Sounds like a case for SBSC.
But you have two software images in the switch, for the purpose of going back to a more stable release.  I guess that was the intention of having two software loads on a switch.
But please open a case with SBSC so this issue can be investigated.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Sorry for this inconvenience and thank you for your purchase.
Regards Dave
