11-28-2017 01:02 PM - edited 03-21-2019 11:18 AM
I am looking for a bit troubleshooting a weird (to me at least) issue.
I have a SG300-52P which is fairly new. It is used mostly with non-PoE devices but also has two phones plugged in that draw their power from the switch. Both have been working fine for the few weeks that the switch has been in place and have developed an issue recently where they simply don't power up.
Here's what I think is the relevant information (showing one port, to keep it simple; the other shows the same symptoms):
on the switch itself:
switch#sh system System Description: SG300-52MP 52-Port Gigabit Max-PoE Managed Switch System Up Time (days,hour:min:sec): 00,00:57:33 System Contact: *** System Name: *** System Location: System MAC Address: 70:6b:b9:*** System Object ID: 1.3.6.1.4.1.9.6.1.83.52.3 Fans Status: OK Unit Temperature (Celsius) Status ------------------------ ------------------------ ------------------------ 1 45 OK switch#sh ver SW version 1.4.0.88 ( date 06-Aug-2014 time 16:55:55 ) Boot version 1.3.5.06 ( date 21-Jul-2013 time 15:12:10 ) HW version V04 switch#
and on the port specifically:
switch#sh power inline GigabitEthernet 41 Port Powered Device State Status Priority Class -------- -------------------- ---------------- ------------ -------- --------- gi41 Auto Fault low class2 Time range: Power limit: 30.0 W Inrush Test: Enable Legacy Mode: Enable Port Status: Port is off - detection is in process Overload Counter: 0 Short Counter: 0 Denied Counter: 0 Absent Counter: 0 Invalid Signature Counter: 0 switch#sh cable-diagnostics tdr interface GE 41 Port Result Length [meters] Date ----------- ----------- ---------------- -------------------------- gi41 OK switch#
That indicates to me that the cabling is not the issue but for some reason the switch cannot negotiate with the device and supply power. I know that the device is not the issue either as it comes on if I plug it e.g. in one of the PoE port of my ASA-5505... so by elimination it has to be switch-related!
I have rebooted the switch to rule that out - it made no difference. I have also tried about half a dozen ports and have the same issue on all, so would be surprised if it was a faulty port.
But I have unfortunately pretty much run out of troubleshooting tests to figure out what the issue is - does someone have a suggestion at all?
11-30-2017 08:09 AM
Are you aware if this issue occurs on all ports of the switch? If not, would you mind testing on a few different ports (ideally not next to each other)?
If the issue occurs on all ports, please upgrade the firmware on your switch to the latest 1.4.8.6 and perform a factory reset (make sure to create a backup of your configuration).
If the issue is still not resolved you may be facing a hardware issue so I'd suggest to contact me or our support centre for further assistance so we can open a service request for you.
Kris
12-01-2017 04:01 AM
12-01-2017 08:43 AM
I ran into a similar problem with a single device in my environment. It ended up being a bad punch in the wall jack at the persons desk rather than external cabling. I read that you have tested using a PoE port on your ASA-5505, when you tested did you happen to move the phone in with the ASA or did you just reroute the cable in the closet? If you moved the phone it might be a good idea to check the wall port.
12-01-2017 11:53 PM
