SG300 debug-mode password
nvong
Anyone knows the default password?
10 Replies 10
DALOAY
The password for debug-mode of SG300 and SG500 is "debug".
Do any know what i can quit from debug mode? Switch on debug mode wrote, that i can enter debug or help.
Hello Anton,
Try ctrl+c
Cheers,
Mike
I mean how to leave this mode that it was loaded firmware?
Whether correctly I am understood if the switch is loaded in this mode, means the firmware(or flash) has broken what then to do?
Hello Anton,
Can you screenshot this mode and attach here?
Cheers,
Mike
Switch working in stack, but in console only this mode, i cant reboot it now for more logs in console screen, because people is still working.
Hi again Anton,
Sx300 switches cannot form stack - what is your model exactly?
SG500x-48
Anton,
You are connected to different unit than Stack Master. Console is available only on Stack Master.
Cheers,
Mike
You was right! Thanks, maby U can help me in this question:
Thats stack
WEST-SG500X-TLT#show bootvar
Unit  Image  Filename   Version    Date                    Status
1     1      image-1    1.4.7.6    07-Dec-2016  18:41:18   Not active
1     2      image-2    1.4.8.6    10-Jul-2017  17:07:52   Active*
2     1      image-1    1.4.7.6    07-Dec-2016  18:41:18   Not active
2     2      image-2    1.4.8.6    10-Jul-2017  17:07:52   Active*
3     1      image-1    1.4.8.6    10-Jul-2017  17:07:52   Active*
3     2      image-2    1.4.7.6    07-Dec-2016  18:41:18   Not active
I want to upgrade firmware, but no free space on flash. How i can pass to everyone switch and delete old fw-file, in unit 1 and unit 2 its image-1, in unit 3 ints image-2.
If i write command "stack unit 1", "stack unit 3" i see the same result:
WEST-SG500X-TLT#stack unit 1
WEST-SG500X-TLT(sg500x)#do dir
Directory of flash:
     File Name      Permission Flash Size Data Size        Modified
backuplo                rw       655200      26      12-Jan-2014 18:05:21
debug                   rw       65520      65520    29-Mar-2015 16:26:13
dhcpdb.sys              r-       65520       --      12-Jan-2014 18:04:59
dhcpsn.prv              --       65520       --      12-Jan-2014 18:04:59
directry.prv            --       65520       --      12-Jan-2014 18:04:59
image-1                 rw      10544364  10544364   31-Mar-2017 22:21:41
image-2                 rw      10554794  10554794   30-Oct-2017 18:53:07
mirror-config           rw      1048320     19328    05-Jul-2018 11:53:31
startup-config          rw      1048320     32577    01-Aug-2018 16:04:38
syslog1.sys             r-       131040      --      01-Aug-2018 14:04:37
syslog2.sys             r-       131040      --      01-Aug-2018 14:04:37
Total size of flash: 32899072 bytes
Free size of flash: 6623802 bytes
WEST-SG500X-TLT#stack unit 3
Directory of flash:
