SG300 ifLastChange incorrect / overflow
torstenvielhak
Hi there,
I have a problem with all SG300 firmwares. The ifLastChange value (which is in timeticks after last restart of the switch) has some kind of overflow around 50 days... at the moment I have no counter which is greater than
.1.3.6.1.2.1.2.2.1.9.68 = Timeticks: (417702434) 48 days, 8:17:04.34
instead this switch has an uptime of
sysUpTimeInstance = Timeticks: (3833554704) 443 days, 16:45:47.04
The problem is still present in 1.4.1.3.
BR
Torsten
Aleksandra Dargiel
Hi Torsten,
Have you opened the ticket with Small Business support team?
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
Hi Aleksandra,
thanks for your reply. I am not sure if we can open a ticket because all SG300 are older than 1 year and we have no service contract for them?!
On the other hand we had a maintenance last month and I also upgraded all our switches to 1.4.1.3. So I have no example switch at the moment. We have to wait ~20days.
BR
Torsten
Hi Torsten,
Right, I understand. This may be device limitation but I could not see any change point when converted into binary.
I would forward this topic to development team however feel free to open ticket with SBSC team once you have relevant logs. Warranty limitations should not be an issue since the problem seems to be related to design rather your specific implementation.
Aleksandra
