SG350X-24P: PoE not working on some ports any more
I own a SG350X-24P which worked flawlessly until today. Now several ports don't supply PoE power any more. Resetting and power cycle didn't help.
Now I get the following after checking "show power inline" at the CLI prompt:
Unit Module Nominal Consumed Temp (C) PSE chipset  Power (W) Power (W) HW Revision
1 SG350X-24P 185 26 (14%) 58 PD69208 - 0x4AC2
PD69208 - 0x4AC2
PD69208* - 0x4AC2
PD69204 - 0x4AC2
Please note the "*" after "PD69208" in line 3. This * was never there before and I expect that it means "problem with this PoE controller". The non-powered PoE PD-devices work without trouble on other ports (i.e. devices on gi1/0/9 ~ gi1/0/11 are all not-powered, (12~ 15 are non-PoE devices). If I move the PoE PD-device from gi1/0/9 to gi1/0/1 it is immediatly powered by the cisco SG350x-24p.
Please advise what to do.
  Carsten
You just need to register as a customer on cisco.com ( it is for free)
Please rate this post or marked as answered to help other Cisco customers.
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
6 Replies 6
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
It will be good to call our support line and open a support case.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Thanks for your prompt reply. Actually I tried this and they asked me for a "Cisco ID". I don't have a support contract, but I expect a hardware issue (and in this case I expect that I wont need a support contract).
   Carsten
Iliya Gatsev
Thanks for your answer. I talked to support and they sent me a ticket number and they will open a RMA case.
  Carsten
so what was the problem? how to fix it?
Hello krufka,
The device was simply broken. A hardware replacement under the device warranty (RMA) was necessary. It seems to me that the devices with hardware version "V01" are susceptible to this problem. I now have a SG350X-24P with hardware version V04 and so far no problems. This device uses a different PoE controller chip.
  Carsten
