Show inventory SG220 / SG300
Is there an equivalent to the IOS show inventory command on the SG220 and SG300? There is a show inventory on them, but it makes you specify an interface to get info on the installed SFP. I'm looking for something in CLI that gives model/PID and serial of the switch, the way IOS devices do.
Seb Rupik
Hi there,
Are you sure? What version of firmware are you running? The SG300 on my desk running 1.4.7.6 has a show inventory command that completes without specifying an interface and displays the output you are after.
cheers,
Seb.
Wow, this is crazy. You can do show inventory but you can't do show inv.
xxxx#sho inventory
NAME: "1" DESCR: "SG300-52P 52-Port Gigabit PoE Managed Switch"
PID: SG300-52P-K9 VID: V03 SN: xxxxxxxx
xxxx#sho inv
% missing mandatory parameter
