Show IP Table on Cisco SG-200-008
David Wank
I'm new to CISCO and I looked in the help but I can't find an answer.
in my SG 200-08 switch, how to I find an IP table so I can see the MAC addresses in a table with the assigned IP address?  I looked everywhere and I can't find it..
Thanks in advance!
devils_advocate
Level 7
Level 7
The SG200 is Layer 2 only so I don't know how much information you will get.
Look down the menu at the left and look for the 'Arp' option which will show you IP to MAC mappings. I am not sure if this will give you all the entries though, you need to look at the ARP cache of whatever is doing your routing as this should be accurate.
Another option is the DHCP bindings on the router.
devils_advocate
Level 7
Level 7
Thanks! I forgot it's a level 2 switch!
I found the other info in my router.
