SLM2008 Mangement vlan
Robert-Brandin
I have tried to config my slm2008, but it doesent work
I try to connect my slm2008 from a trunk port ( port 1) with my mangement vlan 909
But i doesent work ? some proposal
This i my config:
Port 1     vlan 909,900,901,908
Port 2     vlan 900
Port 3     vlan 900
Port 4     vlan 908
Port 5     vlan 901
Port 6     vlan 901
Port 7     vlan 901
Port 8     vlan 901
( I have attach my config )
//Robert
David Carr
Level 6
Level 6
Robert,
The trunk port you have setup on port 1, what is it going to?
Does it know of vlan 909?
As long as that device and a layer 3 device knows of vlan 909 it should allow connection.
You have a default gateway so as long as 172.16.1.1 knows of the vlans you should be good.
