Small Business - SG500-52P losing vlan native when reloaded
ricarva88
Hi guys.
Do someone already faced some problem with SG500 regarding configuration loss when equipment is reloaded?
I'm facing the following issue:
I have some access interfaces configured with the native VLAN different from default (VLAN 1). For example VLAN 60. See below:
interface gigabitethernet1/2
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
switchport trunk allowed vlan add 65
switchport trunk native vlan 60
macro description ip_phone
!next command is internal.
macro auto smartport dynamic_type ip_phone
The configuration is saved. When the equipment is reloaded, this "switchport trunk native vlan 60" command disappear for some reason. All the interfaces with the native vlan different from 1 loose the configuration.
2 Accepted Solutions
Macros just get in the way in small business switches. I had similar issue. My switch was reverting native vlan to 1 anytime switch with native vlan 1 is connected to it. Now I make sure that macros are disabled. "no macro auto" is command under global config.
Please refer to this post as well:
https://supportforums.cisco.com/discussion/11380886/need-help-configuring-voice-vlan-sg300
Let me know if that helps,
Nenad
Michal Bruncko
Level 4
Level 4
thats because you are using smartport configuration. and each macro which is applied on macro-enabled switchport has pre-defined values of native and voice vlans.
you can override them with adjusting corresponding values:
  • using webGUI in "Smartport" -> "Smartport type settings" -> select "ip_phone" (like it's used in your example switchport) -> click on "Edit..." -> and adjust $native_vlan parameter from "1" to your "60"
  • using CLI:
    • switch(config)#macro auto built-in parameters ip_phone $native_vlan 60
  • do the same for all smartport types you're using in your configuration and save config.
Nenad
Nenad,
Thank you for the information.
Best regards.
Michal Bruncko
Level 4
Level 4
  • using CLI:
ricarva88
Michael,
Tested here and it worked.
Best regards.
