I have an issue with using IGMP snooping on SPS224G4.
After some period of using I get such message in log:
%BRG_IGMP-W-TABLE_OVERFLOW: IGMP group table overflow
After a little time after event the switch became uncontrollable.
Normal functionality returns only after hard reboot.
On the switches we use MVR and the static multicast groups are configured on them.
Update to the latest firmware version (1.0.6) has not solved the problem.
If it will be necessity, I can attach configuration file.
Will be glad for any help in solving the problem.
