Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 554 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5525 Views
  • 1 replies
  • 16 Helpful votes
Hello,after writing this post at the forum: http://homecommunity.cisco.com/t5/Wired-Adapters/SLM2008-dropping-packaged/td-p/497730But "iamgiantherockstar" Told me to turn to this support forum.I have recently looket at the following thread: http://ho...
kompis_83 by Level 1
  • 1220 Views
  • 0 replies
Resolved! Cisco SF300 Switch
Dear All,I am going to purchse  SF 300 24p POE Switch and could anyone tell me if this Switch supports the configuration via console ?As i have ESW-500 Sieries switches and it doesnot support console !Please give me the  answer for this question !Tha...
Hi at all,i'm newbie with networking and this is my first post here.i've these problem: ineed to configure 2 vlan on my switch: a new cisco sg300-28p and a hp procurve 2510g. i need to have 2 vlan (vlanid 1 and vlanid3) with static port assign but sh...
HiI hope this is the right place to post and if not, please forward to the right place. I have 4 PCs on the network that I connect to a SRW224G4 switch (which goes to a router followed by a DSL modem). All PCs were doing just great untill employees s...
We are using a SD2005 unmanaged switch and the requirement has changed to require DoD Information Assurance to be applied.I have not found any user's guide to allow any configuration of the SD 2005.Is configuration possible on an unmanaged switch and...
KratosDEI by Level 1
  • 1137 Views
  • 1 replies
Greetings.I have an SG-300-IP Gig POE switch installed and connected to a Cisco 1921 router - in turn conected to DSL.I have the router running DHCP.  Hosts can connect - get and IP and relevant DNS servers - can ping Internetby name and number - but...
iholdings by Level 1
  • 1256 Views
  • 1 replies
Hi Everyone, first question i've posted, i'll try and give as much information as possible, i'm an extremely quick learner as well and have been around networking for nearly 20 years but this is my first outing into the medium sized VoIP deployment w...
voipman73 by Level 1
  • 3335 Views
  • 1 replies
Hi Guys,I am using around 5 sg300's with a lot of Crestron AV kit / touchscreens. About once every couple of months the touchscreens all stop responding. We have found that a reboot of the Cisco switch attached to the touchscreens brings everything b...
phcjpp123 by Level 1
  • 1051 Views
  • 2 replies
We have two SG300-38 switches, both updated to the latest firmware (1.1.2.0), and both experimenting a strange problem in the MAC Address Table. It seems that the switches can not learn mac address, or forget too quickly the MACs learned. The switche...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
