Showing results forĀ
Search instead forĀ
Did you mean:Ā
SRW2024 - HOSTG_rscode_file_load: could not load file
angelo1969
Hello
I'm able to connect to the switch via HyperTerminal. I see that the switch is always rebooting because it can't load the boot file:
-> HOSTG_rscode_file_load: could not load file
I have check in the internet for a solution and I could find different notes about the  runtop_boot-101.rfb file for a SRW2024 switch. But I couldn't find a link where to get the file.
Please could you help me? Thank you very much.
Angelo
As additional information here also the output of the console:
BOOT Software Version 1.0.0.03 Built  08-Jun-2004  09:48:10
CPU - FireFox 88E6218 ARM946E-S processor
64 MByte SDRAM. I-Cache 8 KB. D-Cache 8 KB. Cache Enabled.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
Decompressing SW from flash
Perform WARM BOOT ...
angelo1969
I have found the solution:
Import the file "srw2016-24-10086.ros" (stored as SRW2024_V1_0_Firmware.zip on www.cisco.com/support) using HyperTermin and Xmodem:
- Configure HyperTerminal -> set baud rate to 38400
- Switch on the switch
- During the POST press immediatly the key
- Choose [1] Download Software and click with teh right mouse button anywhere on the HyperTerminal window
- select "Send File"
- Browse to the file "srw2016-24-10086.ros"
- Define the protocol Xmodem
Wait about 25 minutes to finish the transfer... After the problem should be resolve!
Caution: If you import the file "ls20xx-12230.ros" the problem happens again. That what happens on my switch (?)
Hi Angelo,
By the looks of your explaination you basically seem to have reloaded a software version back onto the unit.
Thank you very much for letting us all know the result.  We all learn from this community.
regards Dave
