SRW224: find the ip adress (webgui)
itvancanneyt
hi,
I have several SRW244 switches. It has been a while and I cannot find all of the ip adresses.
Is there a way to scan the netwerk and find the switch to change the ip adress?
I've tried the  Cisco network Assistant, but no luck there...
mrazmik
It can be done. Assuming you at least know the IP subnet address.
1. Collect all SRW switches mac adresses form their lable tags.
2. Download from internet any free IP scan software and install it on your PC. Then scan active ip addresses in the subnet.
3. Check arp table to match switch mac address to its IP address.
houstonjbw
Use a port scanner. It should have the ports for http and telnet (or SSL) open.
