Stack of 2 SG300-20 ?
nicolastailler
I need to stack 2 switches SG300-20. I want to know if it's possible to do it.
I did find something in the datasheet but i found this article (https://supportforums.cisco.com/discussion/11335951/sg300-unit-stacking-mode) and it seems that it's possible to do it.
Can you confirm that it's possible ?
Many thanks,
Nicolas
5 Replies 5
ruwyatt
Stacking is not supported in the 300 series switches. Only the 500 series support stacking.
.:|:.:|:. CISCO | Russ Wyatt | Network Engineer | Cisco Technical Support
Thanks for your answer.
Have a good day,
Nicolas
In the case of, ...
I will buy SG500,
Wich shall i need to stack 2 * SG500 ?
Thanks a lot
Nicolas
The 500 series switches support hybrid stacking so you can use any of the switches from the datasheet below.
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/c78-695646_data_sheet.html
The SG500X supports 10Gig stack links when using the supported stacking cables.
http://www.cisco.com/c/dam/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/at_a_glance_c45-726838.pdf
Thanks a lot, Ruwyatt.
NIcolas
