02-06-2015 05:23 AM
Hello.,
We are going a have Cisco iWAN network made of 170 branches w/ 600 switches. It is plan on the LAN, deploy SG300 as a access switch (as it is a cost oriented solution). We have seen some links (see below) that explains support for LMS, DHCP, but and we do not feel comfortable enough. Obviously we are going to run a labo, that it will necessary order some stuff, but in the mean time, we will appreciate advise on the following matters.
A) If we use w/ PI2.1 to 2.2 on that switches (SG's), which level of support is/will give us?, What can be done?, monitoring, discovering, config, images, etc.. & B) There is example/techtip of massive deployment of SG's by request a startup config, using DHCP options.?
Thks. in advance. Eduard.
https://supportforums.cisco.com/document/143821/cisco-prime-lms-support-small-business-switches
Solved! Go to Solution.
02-24-2015 06:02 AM
Eduardo,
Please send me your email address off list. I have some information which I hope would be of assistance.
Thanks.
Yiukay Lee
Concentrix at Cisco
.:|:.:|:. CISCO | YiuKay Lee | Network Engineer | SMB Pre-Sales | yiulee@cisco.com
02-24-2015 06:02 AM
Eduardo,
Thanks.
Yiukay Lee
Concentrix at Cisco
