system light SLM248G blinking
allert001
I am not able to contact the switch. The system light is blinking continuously.
Probably the device is out of warranty. Is there some kind of procedure that you can try?
LJ Gabrillo
Level 5
Level 5
If it has a console port, then access is through console. Check it logs/display
Linksys is not a part of Cisco anymore
It is now of Belkin
