vlan problems on an SF 300-24P
mdafforn
I have a stack of SGE2010P switches with 3 vlans (1, 10 and 255) on it. Connected to it via a trunk port, I have a SF300-24P.
On the trunk ports, I have vlan 1 untagged, vlans 10 and 255 tagged (on both sides, obviously).
On the SGE2010 stack, I can set a ports primary vlan id to vlan 10, and workstations work correctly.
On the SF300, if I set a port to type general, and the ports default vlan to 10  (on the port to vlan page), I cannot get any communication to work.
This is my first time with a non-CLI switch, and am having real problems figuring out how to troubleshoot this problem.
Any pointers would be appreciated.
Mike
David Hornstein
Level 7
Level 7
Hi mike
With the SF300 switch, why not leave the switch port in trunk  mode .
step 1.  verify and if needed upgrade to firmware version 1.1.2.0 as of yesterday,.  but 1.1.1.8 will give you CLI
step 2. put the ports back into trunk mode, the default setting.
Step 3, you have already created the vlan, but i went through the process below..
Step 4.  The ports are all in the default TRUNK  mode allowing one untagged vlan and multiple tagged vlans per port.
Step 5.  I selected VLAN 10  from the drop down and then clicked Go.
step 6. Below I selected ports 5 to 7 as untagged in vlan 10  and my trunk port 28 tagged in vlan 10 then clicked apply.
(port 28 will now transmit untagged ethernet frames belonging to the default vlan and also tagged frames for vlan 10.)
In the following screen capture,  I verified that ports 5 to 7  were now excluded from the default vlan.
That's it. hopefully pretty easy to duplicate.
Below is the CLI created via the GUI, but to access the CLI interface  via the  telnet,  you must  first enable telnet service  as seen by the following screen capture.
switch4cf17c#sh run
interface  gi28
spanning-tree link-type point-to-point
exit
vlan database
vlan 10,100
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switch4cf17c
no snmp-server server
ip telnet server
interface gigabitethernet5
switchport trunk native vlan 10
exit
interface gigabitethernet6
exit
interface gigabitethernet7
exit
interface gigabitethernet28
switchport trunk allowed vlan add 10
exit
interface vlan 10
name blue
exit
switch4cf17c#
Hope this helps
regards Dave
