10G MMF Transceiver help
tim829
We have a MMF run that's about 400m that we want to take from 1Gb to 10Gb. We're having a hard time finding a transceiver that fits the specifications, any suggestions? I haven't been able to find a single MMF 10GB transceiver capable of going over 300m.
Reza Sharifi
What type of equipment is this for?
Can you provide the part number or the model?
See table-1 in this link:
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/product_data_sheet0900aecd8033f885.html
All Cisco, this would be a link between a 4500 and a 3850.
If your fiber is OM4, it does support 400 meters.
OM3 supports up to 300 meters.
see link for more info:
http://www.lanshack.com/Fiber-Type-vs-Speed-and-Distance.aspx
