Showing results forĀ
Search instead forĀ
Did you mean:Ā
10G network modules
Russell Pearson
Level 2
Level 2
Hey there,
I just purchased and received two Cat 3k-x 10G- T network modules. When I plug them into the switch, the logs show:
004613: Feb  8 10:44:18.037: %PLATFORM-4-FRULINK_UNSUPPORTED: Unsupported FRULink 10G NS module inserted in Switch 1. Remove the unsupported module and insert a supported FRULink module.
004614: 000183: Feb  8 10:44:21.199: %PLATFORM-4-FRULINK_UNSUPPORTED: Unsupported FRULink 10G NS module inserted in Switch 2. Remove the unsupported module and insert a supported FRULink module.
I'm using two 3750E switches with flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
Any help?
Russell Pearson
Level 2
Level 2
Maybe I need to upgrade the ios to 15.0...even though I don't see anything about 10G modules in the release notes.
peppemon
Russel,
please take a look at
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_1_se/release/notes/OL25302.html
for module C3KX-NM-10GT Supported by Minimum Cisco IOS Release is 15.0(1)SE
Peppe
Thank you!
