06-30-2012 01:04 PM - edited 03-07-2019 07:32 AM
What type of twinaxial 10GB is the rigth cable if I want connect two catalyst supervisors (two 4500/6500) with 10GB uplinks?.
Do I need use active or passive ?.
Is enougth with the SFP+Twinax cable like SFP-H10GB-xxx ? or do I need an aditional part like a SFP?.
Thanks.
06-30-2012 01:14 PM
As per my knowledge you should go with active .
The uplink ports visible on the front are GBIC (GigaBit Interface Converter) that can be used as normal Gigabit interfaces. By using different GBIC's you can connect multimode, singlemode fiber optic cable or standard CAT5e/CAT6 Ethernet cabling. These ports can come in handy when you're approaching your switch's full capacity.
May be it is the answer of your question?
Please rate if it helps.
07-02-2012 09:46 AM
Thanks for your answer.
I need the certainty that copper twinaxial cable will work between two 7-E supervisors (cat4510R-E).
Thanks.
06-30-2012 02:48 PM
See my answer in your other post
07-02-2012 09:46 AM
Thanks Reza, I need the certainty that copper twinaxial cable will work between two 7-E supervisors (cat4510R-E).
Thanks.
