10GBASE-LR link won't stand up
Alex Hwang
I am trying to commission new 10Gbps LR link over SMF using two C3750x switches but the link doesn't come up. The end to end distance is less then 10km.
I have checked transceiver details and TX/RX dBm is normal range. Can someone please advise what else I should check?
Here is details of switch-A and switch-B.
Switch-A#sh int t5/1/1
TenGigabitEthernet5/1/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is 1cdf.0f4f.9ec1 (bia 1cdf.0f4f.9ec1)
  Internet address is 10.10.10.1/30
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive not set
  Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-LR
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
Switch-A#sh int t5/1/1 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Te5/1/1     23.5                75.0        70.0         0.0       -6.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Te5/1/1    3.34                  3.70        3.60        3.00       2.90
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Te5/1/1     -2.8                 3.5         0.4        -8.2      -12.2
           Receive Power      Threshold   Threshold  Threshold  Threshold
Te5/1/1    -12.6                 3.5         0.4       -13.8      -14.1
Switch-B#
Switch-B#sh int t4/1/1
TenGigabitEthernet4/1/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is 1cdf.0f4f.98c1 (bia 1cdf.0f4f.98c1)
  Internet address is 10.10.10.2/30
  Keepalive not set
Switch-B#sh int t4/1/1 transceiver detail
Te4/1/1     25.9                75.0        70.0         0.0       -6.0
Te4/1/1    3.34                  3.70        3.60        3.00       2.90
Te4/1/1     -3.6                 3.5         0.4        -8.2      -12.2
Te4/1/1    -10.2                 3.5         0.4       -13.8      -14.1
7 Replies 7
Dan Flesaru
- try to switch fiber optic Rx with TX;
- on both interfaces cmd :  switchport nonegociate
Hi Dan,
I've already tried your both suggestions but didn't make any difference.
Iulian Vaideanu
Level 4
Level 4
Hi Alex,
Here are some things I think might help (some of them are pretty long shots, but you never know...):
- "show version" (maybe it's an IOS bug)
- "show inventory" (for part numbers of the transceivers and the modules they're plugged into)
- what happens if you configure "speed nonegotiate" on both ends?
- are there any multimode fiber patches on the way?
- are you sure that's dark fiber between the switches? it almost looks like each is connected to something other than 10GbE...
Hi Lulian,
- I don't have "show version" information but I don't think this is related to IOS bug as I did same test using other Nexus switches.
- I don't have "show inventory" information but here is information when I tested with Nexus7K.
Nexus7K#sh int e3/17 transceiver details
Ethernet3/17
    transceiver is present
    type is 10Gbase-LR
    name is CISCO-FINISAR
    part number is FTLX1474D3BCL-CS
    revision is A
    serial number is FNS16150CE0
    nominal bitrate is 10300 MBit/sec
    Link length supported for 9/125um fiber is 10 km
- I haven't tried "speed nonegotiate"  But I hard set speed at both end to 10000 FULL. Will try it at next stage.
- I don't think there are MMF patches but I think it is worth double check.
- I confirm that's  dark fiber.
I'm going to ask our fiber team to run end to end OTDR test to see SMF details.
Alex
One quick test then:  if you take a short patch and "loop" any of the problematic transceivers, does the link come up?
Ganesh Hariharan
What is the power value at Mux A end and Mux B end , Are they getting appropriate signal strength.
-GI
Hi Ganeshh
I'm going to ask someone to run end-to-end OTDR test to check signal strength and so on.
