12.2(18)SXE6b replacement
ttgroeneveld
we are using 12.2(18)SXE6b on a C6509 with a WS-SUP720-BASE supervisor. A Cisco engineer told us we should upgrade, as the image is deferred.
Using the software advisor, I cannot find an IOS compatible with the WS-SUP720-BASE, as it only gives me the WS-SUP720-3B as an option.
We are using SSH for mgmt. Other cards installed are WS-X6724-SFP and WS-X6704-10GE.
What IOS should I take?
many thanks in advance,
Tim
iyde
Level 4
Level 4
WS-SUP720-3B will be fine. Your Sup720 is probably that - the WS-SUP720-BASE is just what's written on the front panel. A show version will tell you the type of Supervisor.
You will _probably_ want to go to a 12.2(33)SXI code of the same feature type as your current (IP Base / IP Services or alike), but best to check in the Feature Navigator as well:
www.cisco.com/go/fn
iyde
Level 4
Level 4
www.cisco.com/go/fn
Hi Iyde,
thanks for your reply. It sure helps. I'll have a look at the features of 12.2(33)SXI. I guess it will be sufficient, we're not using special things.
a show version didn't really help me to check the exact type. The front panel only says WS-SUP720.
many thanks and kind regards,
Tim
for your info:
>sh vers
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXE6b, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Thu 25-Jan-07 00:37 by tinhuang
Image text-base: 0x40021040, data-base: 0x42B48000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXE6b, RELEASE SOFTWARE (fc2)
xxxxx uptime is 16 weeks, 6 hours, 33 minutes
Time since xxxxx switched to active is 16 weeks, 6 hours, 33 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 08:33:14 CET Wed Feb 18 2009
System image file is "disk0:s72033-ipservicesk9_wan-mz.122-18.SXE6b.bin"
This product contains cryptographic
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 3.0) with 458720K/65536K bytes of memory.
Processor board ID SMG0904A0FS
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
11 Virtual Ethernet/IEEE 802.3 interfaces
50 Gigabit Ethernet/IEEE 802.3 interfaces
4 Ten Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
xxxxxx>sh mod
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAD092701UU
2 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL09391G69
3 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAD093701D0
5 2 Supervisor Engine 720 (Active) WS-SUP720-BASE SAL09337HCA
Mod MAC addresses Hw Fw Sw Status
1 0013.6067.7532 to 0013.6067.7549 2.3 12.2(14r)S5 12.2(18)SXE6 Ok
2 0015.6305.5cac to 0015.6305.5cc3 2.3 12.2(14r)S5 12.2(18)SXE6 Ok
3 0014.6928.c224 to 0014.6928.c227 2.2 12.2(14r)S5 12.2(18)SXE6 Ok
5 0014.a97d.ae88 to 0014.a97d.ae8b 3.3 8.1(3) 12.2(18)SXE6 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAD09370918 2.0 Ok
2 Centralized Forwarding Card WS-F6700-CFC SAD084002ZX 2.0 Ok
3 Centralized Forwarding Card WS-F6700-CFC SAD0926026B 2.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3A SAL09326ZDF 2.5 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL093270JF 2.5 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
5 Pass
