16/24 Port ethernet card for 2800
nithinvgopal
I am looking a 16 or 24 Port Ethernet (NON POE) card for my 2800 Cisco Router
NM-16ESW is EOL/EOS and the replacement is shown as SM-ES2-24
However SM-ES2-24 is not supported on Cisco 2800 Series
What would be appropriate part- Appreciate your  quick response
Best Regards
Nitin
Reza Sharifi
You can use NME-16ES-1G (16 port 10/100) on your 2800 (2811, 2821, 2851).
have a look at table-7 in this link:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d15f.html
Thanks, for your reply-
Unfortunately NME-16ES-1G is also end of sale.
sharifimr
To:
Nithin Venugopal/United Arab Emirates/GBM/NBR@IBMGMSR
Date:
01/12/2012 04:51 PM
Subject:
- Re: 16/24 Port ethernet card for 2800
Home
created by Reza Sharifi in LAN, Switching and Routing - View the full
discussion
Reply to this message by going to Home
Start a new discussion in LAN, Switching and Routing at Home
