Debugging output of an interface
techguy
Level 4
Level 4
whats is the meaning of following taken out from show interface 0/0
  5 minute input rate 5693000 bits/sec, 501 packets/sec
  5 minute output rate 230000 bits/sec, 269 packets/sec
rsimoni
it means that in the last 5 minutes (it's a rolling average) that interface
received 5.6 Mbits of traffic per second - about 501 packets per seconds
sent out 230Kbits per second - about 269 packets per seconds
Riccardo
below is the configuration of the interface. I have one ACL on this interface. Does it mean that traffic going out from this interface to anywhere OR traffic coming in this interface to LAN users?
interface FastEthernet0/0
ip address 192.168.251.10 255.255.255.0
ip access-group 121 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip nat inside
ip inspect AUH in
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
duplex auto
speed auto
access-list 121 permit udp any eq bootpc any eq bootps
access-list 121 permit udp any eq bootps any eq bootpc
access-list 121 permit tcp any any eq ftp
access-list 121 permit tcp any any eq pop3
access-list 121 permit tcp any any eq smtp
access-list 121 permit tcp any any eq domain
access-list 121 permit udp any any eq domain
access-list 121 permit tcp any any eq www
access-list 121 permit tcp any any eq 81
access-list 121 permit tcp any any eq 143
access-list 121 permit tcp any any eq 443
access-list 121 permit tcp any any eq 3389
access-list 121 permit tcp any any eq 22
access-list 121 permit tcp any any eq 2500
access-list 121 permit tcp any any eq telnet
that output does not care where the traffic is coming from or going to, it just tells how much traffic hits the interface or leaves from it
johnlloyd_13
Level 9
Level 9
hi,
simply put:
5.693 Mbps download
230 kbps upload
you could also adjust the interval on your FE port statistics by using the load-interval interface command (default is 5 mins):
Router(config)#int f0/0
Router(config-if)#load-interval ?
  <30-600>  Load interval delay in seconds
