1721 and more memory
edgar-quintana
This is my cisco 1721 show ver output
Cisco 1721 (MPC860P) processor (revision 0x300) with 61987K/3549K bytes of memory.
Processor board ID FOC07470APD (213828379), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
1 ATM interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Is possible tu purchase more memory to install? or is it at the top?
Which will be the reference to purchase the memory module?
Best regards
4 Accepted Solutions
bjornarsb
Level 4
Level 4
Here is what you need:
Max mem:128 MB
Flash memory not upgradable
BR,
Bjornarsb
mohammedmahmoud
Level 11
Level 11
The Cisco 1721 router supports a maximum 128MB DRAM, so yes you can upgrade your memory.
For upgrading please check:
http://www.memoryx.net
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Amit Singh
Edgar,
You have to open the router and then put the memory in a spare DIMM module. You have an onboard 64MB Dram and you have use the part number MEM1700-64D= to get an additional 64MB memory. Put the meory in spare DIMM mdoule. Please use the link below for the same:
http://www.cisco.com/en/US/products/hw/routers/ps221/prod_configuration_guide09186a0080099429.html
HTH,
-amit singh
9 Replies 9
bjornarsb
Level 4
Level 4
Max mem:128 MB
BR,
Bjornarsb
mohammedmahmoud
Level 11
Level 11
Mohammed Mahmoud.
Which is the best way to do this?
I need to open the router and then, change the memory module and insert the 64 or 128MB module?
Best regards
Check this out:
http://www.memoryx.net/1721.html
And use this link for doing the upgrade:
http://www.cisco.com/en/US/docs/routers/access/1700/1721/hardware/installation/guide/1721upg.html
Mohammed Mahmoud.
Amit Singh
Edgar,
The MAX memory size supported on 1721 router is upto 128MB. This product has already reached EOl/EOS. It will be very hard to get the parts for it now. Check with a local reseller if you can get an addtional 64MB memory and upgarde it to 96 MB. You are already running 64MB DRAM on this.
http://www.cisco.com/en/US/products/hw/routers/ps221/prod_eol_notice0900aecd8044473f.html
Here is the part number for this memory:
MEM1700-64D=
Please see the documentation for upgrading the memory on the router:
HTH,Please rate if it does.
-amit singh
Thks for fast responding...
I know that this router is old, but for me and our work, works really fine.
Now, I've added a 2nd wic (1-enet) for a lmds connection, is there any guide to configure the 1-enet wic??
Best regards
My ISP gives me 5 public address.
Is enougth this wic or would i need the WIC-4ESW Interface Card ?
best regards
Amit Singh
Edgar,
HTH,
-amit singh
