1811 Switch capabilities
nat.watkins
Community Member
Hello all
How do I extend fa0 subnet to the 8 switch ports. I would like to have 1 wan port, and 9 lan ports. Kind of like a $50 linksys router you would buy at walmart.
Thanks for your time
wochanda
Level 8
Level 8
I've forgotten how the port numbering here goes, but I believe we have Fa0 to Fa9. 8 of these ports are layer-2, meaning the only commands accepted are 'switchport access vlan ', and the other is a layer-3 interface, meaning you can configure an IP address directly on it. Assuming Fa0 is the "wan" port, your configuration would look something like this:
ip dhcp pool Private
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
import all
interface fa0
ip address dhcp
ip nat outside
interface range fa1 - 9
switchport access vlan 1
interface vlan1
ip nat inside
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface fa0 overload
The above configuration configures your WAN to get an IP from your DSL/cable modem. Your LAN is configured for DHCP in the 192.168.1.0 range, and the router will be performing NAT in between the LAN and WAN.
Will
Thanks Will for your response. Is there a way to do it without natting inside to outside.
We have 10.2.114.x on outside, we have 10.152.0.0/16 on inside. With 10.152.0.1 assigned to fa0 . What I would like to do is plug a pc into switch and give it a 10.152.0.2,3,4,5,6 and allow it to route to 10.2.114.x
Make sense?
Thank you again
All
Is is possible to route from FA0 and switch ports to FA1. Example, FA1 has 10.2.114.18
and Fa0 has 10.152.0.1 on the Fa0 side I have a whole class B some of which I would like to assign to Pcs and plu into the switch ports.
Sw port 1 would have 10.152.0.2 Sw port 2 would have 10.152.0.3 and so on. I would like for these to route (not nat) to fa1. Is this possible?
