1841 configuration issue
tneelyiii
Hey guys, long time listener, first time caller.
I've been looking at this for too long and I think I want to take a step back and ask you guys for some help. I have an 1841 behind my ISP's (Verizon FIOS) router. I have a single client connected to f0/1 of the 1841, and f0/0 is connected to an ethernet port on my FIOS router. Goes like this;
[ISP Router]->[1841]->[Client]
The network between the ISP Router and the 1841 is a /24 the also includes my "home" network. The default gateway for this network is 192.168.1.1 and is where my default route for the 1841 is pointed. I'm not positive the FIOS router is configured correctly, but if I can reliably pass traffic through the 1841, I'll move onto it. Additionally, the NAT to the public network (ISP's network/Internet) is thus handled by the ISP's router and not necessary in my configuration as far as I can tell.
The problem that I'm having is I cannot seem to get the 1841 to pass traffic from f0/1 to f0/0. NOTHING that I can find in the configuration points me towards an issue.
Current configuration : 1104 bytes
version 12.3
service password-encryption
hostname pub-rtr-01
boot-start-marker
boot-end-marker
enable secret 0 blahblahblahblah
aaa new-model
aaa session-id common
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
boot-start-marker
boot-end-marker
aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
ip domain name pub-rtr-01.et2tech.com
no ftp-server write-enable
username blahblah password 0 blahblahblah
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.17.4.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface Serial0/1/0
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1 permanent
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
transport input ssh
end
Yes, I know I'm running an old IOS version, however I don't have the capability to upgrade at the time (I'll get there as soon as I fix this issue).
From a client on the "home" network (with the ISP router configured as a gateway [192.168.1.1]) I can ping f0/0, but not f0/1.
From a client on the "home" network (with the 1841 configured as a gateway [192.168.1.254]) I can ping f0/0, but not f0/1.
From a client attached to f0/1, I can ping to the ISP router (192.168.1.1), but cannot ping anything on the internet {8.8.8.8).
Is there anything obvious that I'm missing?
Thanks in advance,
Tom
cadet alain
The default gateway for your clients must be on the same subnet as they are(172.17.4.0/24)
Alain
The default gateway for the clients on their respective gateways are correct.
What I'm finding strange is that when I configure the 1841 as the default gateway for a client on the "home" network, I can't even get to the 172.17.4.0/24 network which is directly connected to the 1841 (eth f0/1).
Thanks in advance,
Tom
Tom,
The FIOS router will need a route to
172.17.4.0/24 next hop 192.168.1.254
(your 1841).
The FIOS router will need NAT for your 172.17.4.0
subnet too.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
ok I read more carefully and I understand your topology better now.
Your client has the ISP as the default gateway so when it is ping ping f0/1(172.17.4.1)  as it is a different subnet it is sending the frame to the ISP router which doesn't know about 172.17.4.0/24.
You can add a static route on your home client for this subnet pointing out the 1841(192.168.1.254)
route add 172.17.4.0 mask 255.255.255.0 192.168.1.254 -p   in Windows command line
Windows clients can't use 2 default gateways, if you delete first default gateway before installing this one with
route delete * in command line then you'll be able to ping f0/0 and f0/1 from home client and if icmp redirect is enabled on f0/0 of 1841 it should redirect your home client towards ISP router when you ping 8.8.8.8
Your  ISP router needs a route back to the subnet of the client on f0/1 and it must be configured to nat this subnet
You can nat on your 1841 for this subnet like this:
int f0/0
ip nat out
int f0/1
ip nat in
access-list 100 deny 172.17.4.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit 172.17.4.0 0.0.0.255 any
ip nat inside source list 1 interface f0/0
Alain
