2 nexus 5548 Etherchannel with 6500 result po1a
stephan.kraemer
Hy , i have an problem with connecting 2 5548 nexus with fabric path enabled and vpc together connected with 2 10 g to one 6500 calayst
nexus 5548 (1)
interface Ethernet1/32
  description to core5/4
  switchport mode trunk
  spanning-tree port type network
  channel-group 102 mode active
  no shutdown
interface port-channel102
  speed 10000
nexus 5548 (2)
  description to core5/5
  no shutdown
  speed 10000
6500
interface Port-channel1
description to nexus
switchport
interface TenGigabitEthernet5/4
switchport
channel-group 1 mode active
interface TenGigabitEthernet5/5
switchport
and result in =>                 on cat 6500
Te5/4                           connected    trunk        full    10G 10Gbase-LR
Te5/5                           connected    trunk        full    10G 10Gbase-LR
Po1          to nexus        connected    trunk      a-full    10G
Po1A                            connected    trunk      a-full    10G
does anybody have an solution ?
best regrads
6 Replies 6
Have you checked STP and tried conection without hardcoding the port-channel speed on the nexus?
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
Eric_Wu
Are you trying to VPC to the 6500? If so you are missing the VPC commands on he port channel on the 5Ks. Command is VPC "VPC number". I like to match the VPC number with the port channel number so in your case it would be VPC 120. This is assuming you have all the other VPC requirements setup in the 5ks.
Here is a link.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/configuration_guide_c07-543563.html
Giuseppe Larosa
Hello Stephan,
this should be a minor issue I have seen this in the past and it has been reported some times here in the forums.
The PO1A aggregator is created automatically but this does not mean that your bundle is not working correctly.
This might be caused by:
some differences in capabilities of member ports
or in the dynamic ( different uptime) of the member ports.
Also there is no need in C6500 IOS to manually configure the port-channel interface.
You may try the following, if the new bundle is not already in production:
on C6500:
disable with shut command both member interfaces.
Use interface range to re-enable both member interfaces at once with no shut
If this does not work, you may try to redo everything:
disable both member interfaces with shut command
remove the statement
delete interface port-channel 1
then
use interface range to do the following:
add the line
then do
no shut
Note: you don't need to manually configure the port-channel interface IOS is able to create the port-channel interface configuation on its own as soon as the bundle is operational.
Hope to help
Giuseppe
Hope to help
Giuseppe
stephan.kraemer
Hy thanx the right answer was the vpc statement in the MEC from Eric
The Channel is working now but the STP is blocking
Any idear ..all 3 switches are telling that they are the stp root ..
nexus one
LAN0250
  Spanning tree enabled protocol rstp
  Root ID    Priority    33018
             Address     c84c.75fa.6000
             This bridge is the root
             Hello Time  2  sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    33018  (priority 32768 sys-id-ext 250)
Interface        Role Sts Cost      Prio.Nbr Type
Po5              Desg BKN*1         128.4100 (vPC) P2p *L2GW_Inc
nexus two
VLAN0250
cat 6500
VLAN0250
  Root ID    Priority    4346
             Address     0008.e3ff.fd90
  Bridge ID  Priority    4346   (priority 4096 sys-id-ext 250)
             Aging Time 480
Te1/1/2             Desg FWD 2         128.2050 P2p
Te2/1/2             Desg FWD 2         128.4098 P2p
Po5                 Desg FWD 1         128.5761 P2p
stephan.kraemer
HY sorry this problem result in using fabric path on the vlans , i have set it to ce and now it works.
thanx at all
best regards
Eric_Wu
Awesome. Glad things are working.
