2 Part stacking question
DerikArnie4760
Level 3
Level 3
Part 1: I have a MS225 in use now, two new MS210s and stacking cables. Can I create a stack with all 3 switches and not lose the port config on the one existing switch?
Part 2: I want to have have this stack to have multiple connections to the 2 "Core" Cisco 3850 switches. I assume I would just aggregate several ports as the uplink trunk doing the mirroring this on the "Core" or is there a better way to do this?
Thanks in advance for any help.
note the reply from @DarrenOC that answers question 1, the existing MS225 should keep its config when added to the stack.
@DerikArnie4760 a when you do create your port channels on the Catalyst side make sure you’re using LACP for the aggregation - that’s the only method that the Meraki switches support.
9 Replies 9
MerakiGnome
Meraki Community All-Star
Hi @DerikArnie4760
@as per the below document you can’t physically stack an MS250 and MS210. This is only possible with MS210 and MS225’s
https://documentation.meraki.com/MS/Stacking/Switch_Stacks
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
CMR
@DerikArnie4760 you can bundle connections together for performance and availability and like the 3850s a single port channel can have ports from multiple switches in the stack.
Unfortunately as @DarrenOC said, you cannot stack MS250s and MS210s.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
DerikArnie4760
Level 3
Level 3
Sorry, I type-o’d the switch types. They are an existing MS225 and two new MS210s. I’m updating the original post.
CMR
@DerikArnie4760 you are all good to go then, we have multiple MS225/MS210 mixed stacks and they work nicely, ours are even connected to 3850 stacks, but we use the 10Gb SFP+ ports as uplinks with STP blocking one port rather than using port channels as we don't need 20Gb throughput.
@CMR OK, will the existing config on the MS225 stay when I create the stack or will I need to program it after making that stack?
MerakiGnome
@DerikArnie4760 , all existing switch config will remain. Sounds like you’ve been burnt before by stacking legacy Cisco switches!
Darren OConnor
@DarrenOC Yes I have, lol.
Thanks everyone I got my answers, much appreciated.
MerakiGnome
Hi @DerikArnie4760 , then you’re good to go. Stack away.
Darren OConnor
