ā07-11-2016 03:06 AM - edited ā03-08-2019 06:34 AM
My predecessor had installed 2XCISCO 3750 switches 24 port (implemented LACP on these core switches), we have 4 Comms cabinet on different floors up-linked through fibre to the core cisco switch and all the 4 cabinets have a mixture of D-link, HP switches.
We are going to install a new wireless solution and the vendor has suggested buying 4 POE switches
I am thinking of removing the edge switches (that includes D-link, HP) and gradually replacing with Cisco switches so that I can run proprietary STP versions like Cisco's PVSTand also I can have a single switch vendor environment.
To start with I will be replacing the current D-Link POEs with Cisco POE switch.
Firstly: On each rack these are 100 of LAN Data and for wireless 10-18 POE ports required. So what is the cost effective way. I donāt want to waste any ports and It is a good idea to have a 24\48 port cisco switch.
Secondly: Does these POE Switch need to be a gigabit?
Any suggestions would be grateful
Thanks in advance
Solved! Go to Solution.
ā07-11-2016 03:27 AM
Your call. The APs nowadays are 802.11ac wave 1 compliant. What's the speed of 802.11ac wave 1? Now that's only ONE (1) AP.
Now do the math. Try pushing 300 Mbps data (802.11n) down a 100 Mbps link.
