2511 tty disconect
gary.bartlett
Community Member
Hi All,
I'm sure many of you have a 2511 connecting to your Cisco gear & you simply reverse telnet to your equipment.
Now I'm trying to tweak it a bit, I've been searching & reading for hours on how to clear the tty sessions automatically after a specific amount of time (preferably idle time, for testing 1 minute) to free up the port for others to use, rather than having to telnet in to the 2500 & having to clear the line
Many of the settings below are not part of my normal config, but it's an example of settings I've tried. I'm baffled, I have no problem disconnecting consol or telnet sessions after a specified timeout, so I'm assuming there's something different about either reverse telnet or with async ports, but then again it could be a IOS bug, I?m running Version 12.1(5)T4
Any help would be greatly appreciated, thanks
line 1 16
session-timeout 60
exec-timeout 1 0
timeout login response 60
absolute-timeout 1
login authentication linmethod
modem InOut
transport preferred none
transport input all
stopbits 1.5
modem InOut
transport input all
stopbits 1.5
That should work. At the least, it had worked in my lab in the past.
Can you configure 'no exec' under the tty lines and see if that makes any difference.
I don't know if you looked at this document. Have a look at it.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml#configs
Sundar
9 Replies 9
ahmednaas
Level 8
Level 8
Did you try adding "clear line x" to your 2511 menu?
Thanks for the response, I'm not quite sure exactly you meant by "menu" though. Every time I need to clear the connection I execute the following
TS009# clear line tty 2
[confirm]
[OK]
But what I actually want is for it to be cleared automatically after say 10 minutes of inactivity. For example, the following config is used to clear VTY sessions after 5 minutes of inactivity & I am looking for something similar for TTY, in my mind this should be a simple task, but yet the answer eludes me 😞 I?ve tried everything I can think of & spent so much time searching I thought someone here might have had a similar experience
line vty 0 4
access-class 1600 in
exec-timeout 5 0
login authentication vtymethod
transport input telnet
transport output telnet
Gary
Gary,
Take a look at this config for a 2509. When you telnet into the access-server you get a menu to select which port/device you want to telnet to. If it is not available, you can clear the session from the menu. It is not as automated as what you want but it is quite handy.
! If you go in on the console port then you must issue
! "menu cserver" to start the menu up.
service timestamps debug uptime
service timestamps log uptime
hostname console-server
enable secret cisco
enable password cisco
ip subnet-zero
no ip domain-lookup
ip host c1 2001 10.1.0.1
ip host c2 2002 10.1.0.1
ip host c3 2003 10.1.0.1
ip host c4 2004 10.1.0.1
ip host c5 2005 10.1.0.1
ip host c6 2006 10.1.0.1
ip host c7 2007 10.1.0.1
ip host c8 2008 10.1.0.1
process-max-time 200
interface Loopback20
ip address 10.1.0.1 255.255.255.255
no ip directed-broadcast
interface Ethernet0
ip address 10.1.1.2 255.255.255.0
no ip route-cache
no ip mroute-cache
interface Serial0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface Serial1
no ip address
no ip route-cache
no ip mroute-cache
no shutdown
ip classless
no ip http server
menu cserver title $If you have problems connecting to your device
clear the connection via cl+# (ie:cl1) and try again.
To exit back out to the menu press "CTRL+SHIFT+6"
then "X". You must then clear the connection and
begin a new console session to re-connect to
that device.
1 - Connect to console1
2 - Connect to console2
3 - Connect to console3
4 - Connect to console4
5 - Connect to console5
6 - Connect to console6
7 - Connect to console7
8 - Connect to console8
show - show lines in use | menuexit - exit menu
Exit - logout | $
menu cserver prompt $Please enter command or selection:$
menu cserver command 1 tn c1
menu cserver command 2 tn c2
menu cserver command 3 tn c3
menu cserver command 4 tn c4
menu cserver command 5 tn c5
menu cserver command 6 tn c6
menu cserver command 7 tn c7
menu cserver command 8 tn c8
menu cserver command cl1 cl1
menu cserver command cl2 cl2
menu cserver command cl3 cl3
menu cserver command cl4 cl4
menu cserver command cl5 cl5
menu cserver command cl6 cl6
menu cserver command cl7 cl7
menu cserver command cl8 cl8
menu cserver command menuexit menu-exit
menu cserver command exit exit
menu cserver command show show line tty 1 8
menu cserver options show pause
menu cserver clear-screen
menu cserver single-space
alias exec cl1 clear line 1
alias exec cl2 clear line 2
alias exec cl3 clear line 3
alias exec cl4 clear line 4
alias exec cl5 clear line 5
alias exec cl6 clear line 6
alias exec cl7 clear line 7
alias exec cl8 clear line 8
alias exec tn telnet
privilege exec level 0 clear line
privilege exec level 1 clear
line con 0
exec-timeout 0 0
transport input none
line 1 8
no exec
exec-timeout 0 0
transport input all
telnet break-on-ip
telnet sync-on-break
telnet ip-on-break
flowcontrol hardware
line aux 0
transport input all
line vty 0 4
exec-timeout 0 0
password cisco
login
autocommand menu cserver
end
You have the session timeout set to 60 minutes and not 60 seconds. Can you change the syntax under 'line 0 16' to 'session-timeout 1' and test? This should disconnect the idle reverse telnet session after 1 minute of inactivity.
Sundar
Hi Sundar,
thanks for the reply, I have corrected that, but still without success. I even tried to use the absolute timeout to at least see if I'm on the right track, but nothing...
line 1 16
session-timeout 1 output
exec-timeout 1 0
absolute-timeout 1
transport input all
stopbits 1.5
Thanks for this, I put the menu on the TS, nice... I will use it, but I'm still curious about auto timeout 😉
Sundar
THAT'S IT! I did not come across that page, it clearly is explained by the below
no exec
!--- Unwanted signals from the attached device do not launch.
!--- An EXEC session ensures that the line never becomes unavailable
!--- due to a rogue EXEC process.
Thanks so much!
Glad that helped!
I remember having an issue with the 'exec', which I believe is the default setting, once and turning it off did the trick. It looks like that may cause spurious signals to be sent and the router may interpret this as valid traffic and keeps resetting the timer and the connection never drops.
Sundar
