2514 Router not booting
stevec90
I just upgraded my IOS from TFTP, and it now goes in circles with a software reload. Any suggestions would be appreciated.
$            Toggle cache state
B [filename] [TFTP Server IP address | TFTP Server Name]
             Load and execute system image from ROM or from TFTP server
C [address]  Continue execution [optional address]
D /S M L V   Deposit value V of size S into location L with modifier M
E /S M L     Examine location L with size S with modifier M
G [address]  Begin execution
H            Help for commands
I            Initialize
K            Stack trace
L [filename] [TFTP Server IP address | TFTP Server Name]
             Load system image from ROM or from TFTP server, but do not
             begin execution
O            Show configuration register option settings
P            Set the break point
S            Single step next instruction
T function   Test device (? for help)
Deposit and Examine sizes may be B (byte), L (long) or S (short).
Modifiers may be R (register) or S (byte swap).
Register names are: D0-D7, A0-A6, SS, US, SR, and PC
>T ?
M      Memory test
>B ?
Warning: flash:c2500-d-l.113-11a.bin not in Flash for TFTP serving
Warning: c2500-is-1.123-17.bin not in Flash for TFTP serving
stevec90
restored -- router needed DRAM upgrade to run higher OS.
stevec90
solved
