2610 has no route for directly connected?
CriscoSystems
Level 5
Level 5
Well I've powered up my 2610 (Router Z) and connected it via Ethernet crossover to one of my old 2501's (Router A). The addresses are 10.3.3.1/24 (A) and 10.3.3.26(Z). Router Z has CDP neighborship with Router A and Router A responds to a broadcast ping from Z. But when I try telnet or a unicast ping from Z to 10.3.3.1, nothing happens. (Making Eth0/0 the gateway of last resort at least fixes that, but I don't think I should have to resort to that just to get to a directly connected subnet.)
System image file is "flash:c2600-i-mz.120-3.T3"
Is what I'm seeing normal behavior? 2600's won't automatically have a route for directly connecteds?
Jon Marshall
Seth
No, all routers should have entries for directly connected routes.
Are your subnet masks consistent. Have you tried an extended ping from Z with source IP in 10.3.3.x network - yes i know it should work anyway.
Jon
Well that was weird. I rebooted the 2610 and now everything's fine - I can unicast ping; and 10.3.3.0/24 shows up in the table.
Hooray for reboots...
