Fiber optic cable check command
kilsoo.choi
Visitor
I know that "show cable-diag tdr int [slot/port]" command can check 10/100/1000 etherent link. For example WS-X6748-GE-TX... etc.
But I can find any command to check gigabit only ethernet link. for example WS-X6724-SFP
Is there no command to check fiber link??
Thank you
It's got nothing to do with your IOS. The command "show interface transceiver detail" will NOT work on non-DOM (Digital Optical Monitoring) modules, like the SFP. If you have a 10Gb module or the ruggedized SFP, try and this will work.
What are you trying to test on your cable?
Leo Laohoo
What are you trying to test on the fiberoptic?
Have you tried "show interfaces transceiver detail"?
I tried "show inter g3/3 tran det".
But the switch display below message.
Router#sh int g3/3 tran det
Diagnostic Monitoring Data is not available.
Could tell me why does switch display that message?
My switch' IOS version is 12.2(18)SFX5.
Thanks for your answer.
I want to check a optical dBm at running switch. So I want to forecast a possiblity of optical link problem with low dBm.
Is there any way I want?
Thank you
