2621 problem
olakunle06
Level 3
Level 3
hi everyone,
i have two enet port on this router
fe0/0-10.116.144.1
fe0/1-10.16.144.17.
issue is i have a pc1 connected with .5 and pinging the router fe0/0 interface and pc1 was successfull from the router.however for pc2 connected with .21 i could only ping the router interface fe0/1 .17 but cannot ping pc2 .21 from the router.
with sh ip int bri. all interface are up and show int fa0/1 displays up up as shown.wat could be wrong pls.
show ip int bri
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 10.116.144.1 YES NVRAM up up
Serial0/0 10.116.145.101 YES NVRAM down down
FastEthernet0/1 10.116.144.17 YES NVRAM up up
Serial0/1 10.116.145.201 YES NVRAM down down
Serial0/2 10.116.145.109 YES NVRAM up up
Serial0/3 10.116.145.209 YES NVRAM up up
Serial1/0 10.116.145.133 YES NVRAM up up
Serial1/1 10.116.145.137 YES NVRAM down down
Serial1/2 10.116.145.125 YES NVRAM up up
Serial1/3 10.116.145.225 YES NVRAM down down
#show int fa 0/1
FastEthernet0/1 is up, line protocol is up
Hardware is AmdFE, address is 0017.945d.5921 (bia 0017.945d.5921)
Description: HUBpth2h2
Internet address is 10.116.144.17/28
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:03, output hang never
Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 0 packets/sec
274 packets input, 37966 bytes
Received 98 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
140 packets output, 15670 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
5 lost carrier, 0 no carrier
5 Replies 5
noran01
Level 5
Level 5
Sounds like the wrong gateway and/or subnet mask on PC2. It could also be as simple as a firewall issue not allowing icmp on PC2.
ip and DG are right, and firewall disabled on pc2.but still cannot access.
Is there a "second" firewall still enabled?
e.g.: Turned off Norton firewall, but Windows Firewall was also turned on, and remains on unknown to the user.
I know you don't want to run two simultaneously, but I have seen users do this (knowingly or unknowingly), so I thought I'd ask?
Is there any device (switch, transparent firewall) between the router and PC2 enforcing any ACLs?
Jon Marshall
fe0/0-10.116.144.1
fe0/1-10.16.144.17.
Is fe0/1 address a typo above as your "sh ip int br" output shows fe0/1 having an address of 10.116.144.17 not 10.16.144.17 ie.
What subnet masks are you using on these interfaces and on the PC's ?
Jon
attached are d config
