2691 flash memory
rrice
Community Member
WHat is the maximum amount of flash memory that I can install in a 2691? Also, can I use any standard flash card for the 2691?
ccbootcamp
Level 10
Level 10
128MB of CF flash is the max. Yes, you can use a standard CF flash card.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
