2811 basic nat configuration
jfrackoviak
Community Member
I'm new to configuring a router and I'm lost and I might be over thinking the whole thing but I figured I'd post and see what I get.  I have a link balancer that is getting 2 internet connection from the same isp and because both of the internet connections are coming from the same isp they are within the same subnet.  Each internet connection has 13 static IP's associated with it.  My link balancer is obviously not going to be able to accept both internet connections on the same subnet because there is no way its going to be able to do the routing.  I thought I could creat a simple static nat that would allow me to fool the link balancer into thinking on of the conenctions was on a different subnet.  Basically both of these connections are in front of my firewall so I would really just like the router to NAT everything on one IP and translate it to another IP.
Internet connection 1:  96.212.211.194 - 206
Internet connection 2:  96.212.211.210 - 222
My link balancer on its wan links takes 1 IP so:
wan1:  96.212.211.194
wan2:  192.168.1.2  - hopefully translated by the router
The router has 2 FastEthernet ports 0/0 and 0/1 I've been trying to just configure a static nat and at this point don't even have a starting configuration and I'm hoping to be pointed in the right direction.  Right now the only thing I have on the router and I'm not even sure if its correct is
FastEthernet0/0
ip nat inside
duplex auto
speed auto
FastEthernet0/1
ip address 96.212.211.210 255.255.255.0
ip nat outside
duplex auto
speed auto
I thought I would be able to simply say something like
ip nat inside source static 192.168.1.2 96.212.211.210
Thanks in advance for any help or any direction you can point me in
If I understood your requirement correctly,you have 2 ISP connections. Would like to use one as prmiary and one as secondary, in case one fails...
In such scenario, you should either go with  NAT over DUAL ISP config, or  PBR
Configuring NAT:
For configuring NAT we have to create a route-map which matches the interface.
route-map NAT1
match interface
route-map NAT2
match interface
Create Nat rules.
ip nat inside source route-map NAT1 < interface connected to WAN1> overload
ip nat inside source route-map NAT2 < interface connected to WAN2> overload
For this we need to configure two things :
1)      PBR : Policy based routing to send traffic to specific ISP next hop depending on the source
of the packet.
2)      NAT : For natting the traffic as per the outgoing interface.
Configuration of PBR:
Create an access-list containing the subnet that needs to go through WAN connection 1:
For WAN1
ip access-list 101 permit 192.168.1.0 0.0.0.255 any
For WAN2
ip access-list 102 permit 192.168.2.0 0.0.0.255 any
Now create a route-map to direct traffic matching access-list 101 to WAN1 next hop and the one
matching 102 to WAN2 next hop:
route-map test permit 10
match ip address 101
set ip next-hop
route-map test permit 20
match ip address 102
set ip next-hop
Apply this route-map to the interface from which we receive traffic.
ip policy route-map test
Please rate the post if it helps.
Jyoti
And coming to start with only one WAN connection, you should configure router as below,
interface FastEthernet0/1  <<<<< WAN interface
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
end
interface Vlan1 <<< Internal Management interface
ip nat inside
end
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 101 interface FastEthernet0/1 overload >>> Configure nat
ip route 0.0.0.0 0.0.0.0
