2900 router problems
sirEgGhEaD
howdy. i'm fairly new to cisco stuff. i have an entire collection of cisco books, but i'm not too far in them. currently i'm deployed to iraq and one of my warrant officers here is a cisco instructor. i've learned some stuff from him and learned some stuff on my own. i've presented my situation to him, but it's extremely hard to learn from him in the first place because he's a little off the wall. but besides that, i don't know enough.
i'm a systems adminstrator here in iraq and head of the helpdesk. i've been in IT for over 20 years. i have experience, just not when it comes to this.
so enough of the intro. we have the internet here in our rooms that we pay way too much for. there is one cable for my roommate and myself. we sign into a radius server with a 24 hour lease. the ip addresses are obviously assigned via dhcp. the cable from our room runs to a "dumb" switch. from the switch, a cat5 runs to a line of site radio that shoots to their office down the road. from there they host the internet via satellite obviously.
currently i have a linksys wrt300 acting as my router with the antennas disabled. i need to send this router home to my wife, so my whole grand plan for this expensive router is only to catch the outside ip address given by my isp, and run a dhcp server to host my inside lan. on this switch there are, of course, 2 built-in fastethernet interfaces, a t1/dsu port on the serial interface, and something else that says t1 on the voice interface.
i've tried a few things. i've created an access list, configured nat on the 2 fe interfaces, and semi-setup the dhcp. i have a few problems. obviously, i can't pull up a webpage. i don't receive ping from everything, even from the router console. for instance yahoo.com i cannot receive a ping from. even the default gateway for the isp i can't receive a ping from. but i've randomly pinged a few ips here from behind their radio. another problem is i don't know how to get dhcp to push itself (192.168.1.1) as the gateway down to the computer connected to it. i have to set it manually.
a few other problems that don't really regard the internet side of my problem is somehow i must have fat-fingered my password when i initially set it up, so i had to follow the recovery instructions at cisco.com. since then, the router won't hold a password when it reboots. show config shows the password, but it still doesn't hold. another thing is dir doesn't show anything other than a .bin file. i don't remember which one, but it isn't my ios.
i know this is quite a lot for one post, but i would definately appreciate some help.
thomas
71 Replies 71
Hey Thomas, I hope you had a nice weekend! I was traveling so couldn't reply earlier. Using NAT to fix the single host login problem is very logical. Your config looks fine. How has it been so far?
- Vaibhav
- Vaibhav
it's been great so far. i'm glad i finally got it taken care of. i really appreciate all the help though. i don't know why it didn't like the 192.168.1 net. how was your weekend?
Good to know that all's well. Weekend was good. I think there are some 192.168.1.x devices on any of the sides or some entires cached somewhere. In case you have the time and want to troubleshoot it, the best way would be to isloate the router and then add a device/client at a time.
Have a good one.
-Vaibhav
i think i'll stick with the 172.16 net. would you mind helping me with one more thing before we finish up? i would like for the machines that i have here in my room to be on net 1 and other machines that i have cables running to outside this run to be on net 2. i only want net 1 to access the internet
By net 1 and 2 do you mean - 172.16.1.0/24 and 172.16.2.0/24 respectively? Well, you have a nat pool for 172.16.1.0/24 and if I am not mistaken even the DHCP is assigning IPs in the 172.16.1.0 network. If that's the case, any host on 172.16.2.0/24 should not be able to get on to the internet. However, if the configuration is different and if the hosts from the .2 network are able to get on to the internet, we can put an access list to block internet access for anything from the .2 network. Also let me know if the 172.16.2.0 network devices need to access the Cisco 2600 router for anything at all?
-Vaibhav
yeah you have it right. sorry i guess i should have clarified a little more. 2 would need access to 1 and vice versa. changing dhcp assignment to net 2 wouldn't be hard. is running static ips on the other nets the only way to dhcp more than one net? if so, how do i set up statics for net 1? there won't be that many on 1. we have 7 devices in this room for now, so not too bad.
Thomas,
Here's what you can do:
1. Create another VLAN on the 2950 switch for 172.16.2.0/24. By default, every port will be in VLAN1 which will have internet access:
VLAN1 (Default) - For 172.16.1.0/24 with internet access.
VLAN2 - For 172.16.2.0/24 without internet access.
Configuration on the switch
By default, all the ports on the switch are in VLAN 1. So, every device plugged into the switch will get an IP from the Insayne pool (172.16.1.0/24) and would have internet access.
We will create another VLAN for the .2 network. Any device that is plugged into a port which is in VLAN 2 will get IP address from the InSayne1 pool (172.16.2.0/24 - explained in step 4) and would have internet access at this moment but we will deny it later (last step).
! - Create VLAN2 for ports in the 172.16.2.0/24 network.
Switch# configure terminal
Switch(config)# vlan 2
Switch(config-vlan)# name No-Internet
Switch(config-vlan)# end
! - Example, adding Fa0/2 on the switch to VLAN 2 (No-Internet).
interface FastEthernet0/2
switchport access vlan 2
spanning-tree portfast
Now, you can use the same method to move the desired ports to VLAN 2 in the switch.
2. Configure trunking on the switch
! - Configuring FastEthernet0/1 as the trunk port.
interface FastEthernet0/1
switchport mode trunk
Connect a straight cable from Fa0/1 on the switch to Fa0/1 on the router.
4. Configure two dhcp pools on the router
InSayne - For 172.16.1.0/24 with internet access.
InSayne1 - For 172.16.2.0/24 without internet access.
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 172.16.1.1
ip dhcp excluded-address 172.16.2.1
ip dhcp pool InSayne
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
dns-server 208.67.222.222 208.67.220.220
ip dhcp pool InSayne1
network 172.16.2.0 255.255.255.0
default-router 172.16.2.1
ip nat pool InSayne 172.16.1.1 172.16.1.255 prefix-length 24
ip nat inside source list 15 interface FastEthernet0/0.1 overload
access-list 15 permit 172.16.1.0 0.0.0.255
Remove the ip nat inside statement from fa0/1 and move it to fa0/1.1
int fa0/1
no ip nat inside
no shut
int fa0/1.1
ip nat inside
no shut
5. Configure trunking on the router
Configuration follows:
c2600(config)#int fastEthernet 0/1
c2600(config-if)#no shut
c2600(config-if)#exit
!-- Enable trunking on the sub-interface FastEthernet 0/1.1.
!-- Note that actual trunks are configured on the sub-interfaces.
c2600(config)#int fastEthernet 0/1.1
!-- On the switch, by default, the native VLAN is 1.
!-- On the router, configure VLAN1 as the native VLAN.
c2600(config-subif)#encapsulation dot1Q 1 native
c2600(config-subif)#ip address 172.16.1.1 255.255.255.0
c2600(config-subif)#exit
!-- Enable trunking on the sub-interface FastEthernet 0/1.2
c2600(config)#int fastEthernet 0/1.2
c2600(config-subif)#encapsulation dot1Q 2
!-- Configure L3 information on the sub-interface 0/1.2
c2600(config-subif)#ip address 172.16.2.1 255.255.255.0
c2600(config)#^Z
c2600#write memory
6. Disable internet access for 172.16.2.0/24 on the router.
c2600(config)#access-list 100 permit ip 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
c2600(config)#int fa0/1.2
c2600(config-subif)#ip access-group 100 in
I hope this helps!
-Vaibhav
sorry about the delay. i've been caught up lately. i added the configs in pretty quick. i actually named the no-inet pool InSayneX and used access-list 10 instead of 100. vlan 1 seems to be working fine right now, but i hooked a machine into a port set to vlan 2 today and it doesn't pull an ip. below is my router running-config.
InSayneLAN#show run
Building configuration...
Current configuration : 1855 bytes
version 12.3
hostname InSayneLAN
boot-start-marker
boot-end-marker
enable password *********
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
voice-card 1
ip subnet-zero
ip cef
ip dhcp excluded-address 172.16.1.2 172.16.1.99
ip dhcp excluded-address 172.16.2.2 172.16.2.99
ip dhcp pool InSayneX
no ftp-server write-enable
controller T1 1/0
framing sf
linecode ami
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
no dce-terminal-timing-enable
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
ip nat inside
no snmp trap link-status
interface FastEthernet0/1.2
ip access-group 10 in
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip nat inside source list 15 interface FastEthernet0/0 overload
access-list 10 permit 172.16.2.0 0.0.0.255
access-list 10 permit 172.16.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
end
InSayneLAN#
i had to do things slightly different than you posted. i forgot what the error was that i got. actually i think i wound up with 2. but i worked around them. i know one was i had to set no ip on fa0/1 before i could set that same ip to fa0/1.1. the other, i don't remember what happened.
got any ideas on what's going on? do i need to post my switch's running-config also?
Sorry for the late response. Had been really busy.
Did you try other ports in Vlan 2 as well? Was the port up/up? What if you assign manual IP address from the .2 network to a device on VLAN2. Does it communicate with VLAN 1 and is internet blocked for it?
Also, instead of ACL 10, an extended ACL such as below makes more sense here. It allows traffic from .2 to communicate with .1 but blocks it from accessing any other subnet (which blocks internet access as well).
i remember now what that second problem i was having with your config was. below is what happens when i type what you asked:
InSayneLAN(config)#$ 10 permit ip 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
Translating "ip"...domain server (208.67.222.222) [OK]
access-list 10 permit ip 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
% Invalid input detected at '^' marker.
InSayneLAN(config)#
and below is what happens when i remove "ip" from the command:
InSayneLAN(config)#$ 10 permit 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
access-list 10 permit 172.16.2.0 0.0.0.255 172.16.1.0 0.0.0.255
InSayneLAN(config)#
the forum doesn't show the exact location of the carats for the errors, so i will type them here. the carat in the first error is pointing to the first 0 in the first instance of 0.0.0.255. the carat in the second error is pointing to the first 1 in 172.16.1.0
i manually configured a machine to a net 2 address and plugged it into a vlan 2 port and it successfully pinged a machine on vlan 1. i have also made the following modifications to my router's config in order to have the extended ACL you were talking about:
ip access-list extended No_iNet
ip access-group No_iNet in
sounds good. I hope the .2 network and the ports in vlan 2 donot have internet access.
So at this point only the config through DHCP for vlan 2 is not working ?
Have you checked if DHCP is working after the last 2 changes ? If only DHCP for vlan 2 is down, let me know and we will then work on it further.
that's right. no internet access from vlan 2 and no dhcp from vlan 2. i tested it all after i made the last 2 changes. i briefly looked over the config but i don't know what the problem might be.
