CSCO11544512
Community Member
After upgrading IOS
from
c2900-universalk9-mz.SPA.150-1.M4.bin
to
c2900-universalk9-mz.SPA.152-3.T.bin
I get this message :
%IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = ipbasek9 and License = No valid license found
Any idea ?
Anuloma
Ivan Krimmel
Level 9
Level 9
hi Herve,
this could be because you either lost the license during the upgrade(not sure what is the process to transfer one) or there're some features which previously did not require a license and now they do. This could be for instance ipbasek9 which is missing. Would you mind to share which licesnses are installed at the moment?
No problem. My colleague has opened a support case : Cisco sent him new lic
files
2012/4/24 ikrimmel
Home <> Re: 2911 créé
par Ivan Krimmel <> dans *LAN,
Switching and Routing* - Afficher l'intégralité du fil de discussion<>
so basically the lic has been lost during the upgrade?
Maybe. I've not checked the license before IOS upgrade ...
Le 24 avril 2012 14:35, ikrimmel <
