2912XL switch + Trunk Port
smothuku
Level 7
Level 7
Dear Experts ,
I would like to know whether the following switch supports trunking or not ?
Switch model: WS-C2912-XL-A
CS01#sh version
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)WC7, RELEASE SOFTW
E (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 05-Mar-03 10:26 by antonino
Image text-base: 0x00003000, data-base: 0x0034DEE8
ROM: Bootstrap program is C2900XL boot loader
CS01 uptime is 1 hour, 10 minutes
System image file is "flash:c2900xl-c3h2s-mz.120-5.WC7.bin"
cisco WS-C2912-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K by
s of memory.
Processor board ID FAB0409T13W, with hardware revision 0x01
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
12 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:01:42:DC:D9:80
Motherboard assembly number: 73-3397-08
Power supply part number: 34-0834-01
Motherboard serial number: FAB040844KT
Power supply serial number: PHI033901TY
Model revision number: A0
Motherboard revision number: A0
Model number: WS-C2912-XL-A
System serial number: FAB0409T13W
Configuration register is 0xF
When i enable trunking on f0/11 of switch it is taking commnds neccessary for config.
Trunk link is not working means it is not allowing any vlan traffic.
From below doc i understand that -A model switches doesn't support trunking where as -EN suppoerts...Is it true ?
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/releasesa4/icg/maoverv.html
Satish
ankbhasi
Hi Satish,
'A' model is a standard switch while 'EN' is an enterprise version. But the image which you have loaded I believe is an enterprise image which do gives the functionality of enterprise features on standard switches but sometimes all features do not work.
Can you update if you have baught some upgrade kit to upgrade from A to EN image?
Ankur
