2924XL process memory IP SNMP holdin
h.cox
Hello
This 2924 switch is reporting very high process memory usage. I cannot help noticing that holding column of show proc memory is highest for the IP SNMP usage.
Is it normal for IP SNMP to require a lot of memory or could it be a memory leak?
xxxxxxxxxx#show proc mem
Total: 3779364, Used: 3229356, Free: 550008
 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0      48800       1504     394160          0          0 *Init*
   0   0       1680    9178808       1680          0          0 *Sched*
   0   0   21204200   18959200     988044    1099092     510632 *Dead*
   1   0        268        268       3836          0          0 Load Meter
   2   0     114548       9420       6900      13608          0 TACACS+
   3   0          0     114964       6836          0          0 Check heaps
   4   0      20248          0      27084          0          0 Chunk Manager
   5   0         96      12288       6932          0      34480 Pool Manager
   6   0        268        268       6836          0          0 Timers
   7   0         96          0       6932          0          0 Entity MIB API
   8   0        180        168       7016          0          0 ARP Input
   9   0       8688        268      15256          0          0 Enet Aging
  10   0         96          0       6932          0          0 Critical Bkgnd
  11   0     208692     179288      15916          0          0 Net Background
  12   0      17392        268      18524       9072          0 Logger
  13   0        268        268       6836          0          0 TTY Background
  14   0 1878063884 1380815372       6836          0          0 Per-Second Jobs
  15   0        192          0       7028          0          0 Net Input
  16   0        268        268       6836          0          0 Compute load avg
  17   0          0    3404688       6836          0    7923888 Per-minute Jobs
  18   0 3456702528 2114128928       7980       1560          0 LED Control Proc
  19   0          0          0       3836          0          0 RAM Access (dm 0
  20   0 1142765272  655434380       8616        780          0 Port Status Proc
  21   0        244          0       7080          0          0 VM Prune Events
  22   1     345932     335704      16004          0          0 Virtual Exec
  23   0  902685460  902685252       3908          0          0 GDS Frame Ager
  24   0          0          0       6900          0          0 IP NAT Ager
  28   0          0          0       3836          0          0 RAM Access (dm 1
  30   0 2724120940 1104215440       7308          0          0 Broadcast Storm
  31   0         96          0       3932          0          0 Port Group Chang
  33   0        428     339296       3932          0          0 Address Learning
  34   0          0          0       3836          0          0 RAM Access (dm 2
  35   0 4200168060 3851135040      22936       1560          0 Enet Aging
  36   0    1436732    1073380      15716          0          0 IP Input
  37   0         96     389268       3932          0          0 Address Deletion
  38   0  177488308  168629860      18528    6355440          0 CDP Protocol
  39   0        588        268       7156          0          0 UDLD
  40   0      14748       5332      12416          0          0 Switch CGMP Prot
  41   0      22804      15504      20892          0          0 VLAN Manager
  42   0          0     695688      12836          0          0 TCP Timer
  43   0   10425424     425908      14488          0          0 TCP Protocols
  44   0          0          0       6836          0          0 Socket Timers
  45   0          0          0       6836          0          0 HTTP Timer
  46   0        244          0       4080          0          0 CGMP Forwarding
  47   0        364        268       6932          0          0 Cluster L2
  48   0         96          0       6932          0          0 Cluster RARP
  49   0       1156        600       7392          0          0 Cluster Base
  50   0       4524      13972       7600        780          0 Spanning Tree
  51   0        420        268       3988          0          0 STP Hello
  52   0      50076        268      20548      14040          0 STP Queue Handle
  53   0        328      12592       6996          0          0 Malibu STP Adjus
  54   0          0          0       6836          0          0 Time Range Proce
  55   0         96          0      12932          0          0 SNMP ConfCopyPro
  56   0      12176      13592       3932          0          0 Bridge MIB traps
  58   0        268        268       3836          0          0 Runtime diags
  59   0          0          0       6836          0          0 SNMP Timers
  60   0 1829583108 1828522940    1319796          0          0 IP SNMP
  61   0         96          0      12932          0          0 SNMP Traps
  62   0       1416        268       7984          0          0 NTP
  63   0  117924192  115566088      15236    1261008          0 BootP Resolver
  64   0     254088     142812       7168          0          0 AAA Accounting
                                  3228952 Total
6 Replies 6
Reza Sharifi
Hi H,
Take a look at this doc regarding high CPU with SNMP engine and how to mitigate it.
http://www.ciscosystems.ro/en/US/tech/tk648/tk362/technologies_tech_note09186a00800948e6.shtml
Reza
It was process memory usage rather than high CPU utilisation that I was concerned about.
Giuseppe Larosa
what IOS image is running  on the device?
We experience a different problem that they become unreachable at L3 (no telnet possible, no ping) but they are still acting as L2 switches.
Hope to help
Giuseppe
12.0(5.2)XU Maint Rel
h.cox
The following bug is a memory leak in in IP SNMP. That might be what I am hitting. Unfortunately, none of the fixed-in versions give are available for the 2924XL switch.
h.cox
The bug I meant to say in my previous post was:
CSCds06656 Bug Details   Bug #3 of 3 | < Previous | Next >
memory leak in MakeOctetString() for various get
Problem Description:
Router may experience memory leak in IP SNMP or other processes using
MakeOctetString()
Conditions:
Problem may appear during normal operating conditions when a process
using MakeOctetString()
Possible Workaround:
Disable SNMP or orther process using MakeOctetString()
Status
Fixed
(Resolved)
Severity
3 - moderate
Last Modified
In Last month
Product
Cisco IOS software
Technology
1st Found-In
12.1M
12.0(4)T
12.0(5)T1
12.1T
Known Affected Versions
Fixed-In
12.1(4.1)M
12.0(12.6)SC
12.1(3a)EC1
12.1(4)DB
12.1(4)DC
12.1(4)DC1
12.1(4.0.3)PI
12.1(4.0.3)T
12.1(4.3)PI
12.1(4.4)E
12.1(4.4)EC
Component(s)
ubr7200
Related Bug Information
Processor memory leak in SNMP MakeOctetString
A Cisco router running 12.0(4)T or later 12.0 T code that has Simple
Network Management Protocol (SNMP) configured may experience a slow
memory leak in Processor memory. Workaround: Disable SNMP.
