2950 and 2960 Switch
Bharat Negi
Hi Experts !!!
Request you guys to suggest me the Enhanced Image for 2950 and 2960 switches.
My requirement is to mark the packet on these switches using Class-maps/MQC.
2950
Switch#sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA10a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 24-Jul-07 17:13 by antonino
Image text-base: 0x80010000, data-base: 0x80570000
ROM: Bootstrap program is C2950 boot loader
Switch uptime is 2 hours, 2 minutes
System image file is "flash:c2950-i6q4l2-mz.121-22.EA10a.bin"
cisco WS-C2950-24 (RC32300) processor (revision S0) with 20957K bytes of memory.
Processor board ID FOC1130X1DM
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1C:F9:99:EC:00
Motherboard assembly number: 73-5781-14
Power supply part number: 34-0965-01
Motherboard serial number: FOC11291Y3Y
Power supply serial number: DTH111625SW
Model revision number: S0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: FOC1130X1DM
Configuration register is 0xF
2960
Switch#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
Switch uptime is 2 hours, 4 minutes
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"
cisco WS-C2960-24TT-L (PowerPC405) processor (revision D0) with 61440K/4088K bytes of memory.
Processor board ID FOC1219Y71U
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:21:D7:13:4F:80
Motherboard assembly number : 73-10390-04
Power supply part number : 341-0097-02
Motherboard serial number : FOC12196XF5
Power supply serial number : DCA121889SV
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C2960-24TT-L
System serial number : FOC1219Y71U
Top Assembly Part Number : 800-27221-03
Top Assembly Revision Number : B0
Version ID : V03
CLEI Code Number : COM3L00BRB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24TT-L 12.2(35)SE5 C2960-LANBASE-M
bsn
The Catalyst 2950 runs a common image and depending on the hardware runs either the SI or the EI Feature set. You can't upgrade a 2950 that has SI features to EI features:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea12/release/notes/OL16966.html#wp998833
You have a WS-C2950-24 which only runs the SI features so QoS is very limited on it. You cannot use ingress service-policies to mark, remark or police your traffic. The only QoS features it has are layer-2 - trust CoS on a trunk, set a default CoS and queue based on the CoS value.
The 2960 on the other hand has two separate IOS feature sets - LAN Base & LAN Lite - and which one you run is not hardware dependant, however it is licensed. Luckily you already have the LAN Base image installed.
The LAN Base feature set has quite rich QoS features and you can mark, remark & police traffic on ingress. You are limited (like the 2950EI) to a minimum policing rate of 1Mbps though which might be restrictive?
Have a read of the 2960 QoS configuration guide here: http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swqos.html
I would also suggest you take a look at the 'Enterprise QoS Solution Reference Network Design Guide Version 3.3' as this has working examples of configuration for the 2960 (plus 2950 and all other Catalysts) here:
http://www.cisco.com/go/srnd
Andy
Andy
