2950 IOS release for DHCP client
I am trying to enable my Cisco 2950 as a DHCP client (I know this is not how it works in real life) for test purpose in the lab. That is the switch should receive an ip address by the router which it is connected to, I have configured the router to be a DHCP Server
The current switches I have does not support the switch to be a DHCP client
Switch 1 - c2950-i6q4l2-mz.121-13.EA1c.bin
 Switch 2 - c2950-i6q4l2-mz.121-22.EA1b.bin
Switch 3 - c2950-i6q4l2-mz.121-19.EA1a.bin
Switch 4 - c2950-i6q4l2-mz.121-13.EA1c.bin
Can you please tell me which IOS for Cisco 2950 supports DHCP client?
Switch config (that should be)
SW# conf tSW(config)# int vlan 1
SW(config-if)# no ip address
SW(config-if)# ip address dhcp client-id Vlan 1
Unable to get this far since my ios does not support the DHCP client feature. Output from my Switch:
Switch001(config)#int vlan 1
Switch001(config-if)#ip address ?
  A.B.C.D  IP address
 **** no option for DHCP
Peter Paluch
Unfortunately, no 2950 IOS, to my best knowledge, has an explicit ip address dhcp command. What I have only observed - almost by an accident - is that when a 2950 Catalyst has its configuration cleared and is rebooted while being connected to a network running DHCP server, it will obtain its IP address during its bootup process via DHCP and will configure this IP address automatically on the interface Vlan1. Apart from this, though, I do not know of any other option.
Best regards,
Peter
