2950 SYST LIGHT FLASHING
bryan.e.jones
We have inherited a 2950 switch. The switch does not boot, and the console shows nothing. The SYST light flashes amber continously.
Any assistance is appreciated!
Bryan
ankbhasi
Hi Bryan,
If you do not see anything on console there is nothing much can be do other then replacing your switch.
You can try changing console cable if you haven't and give it a try. Also try changing baud rate on your hyper terminal and se if you get anything on console and if still no luck sad to say its bad hardware.
Ankur
