2960 - Avaya IP phone - Port security problem
dchavarria
          Hi, I have a problem with a Switch 2960 and a telephone Avaya, its activate the command port securit, the topology is Switch 2960 port + Avaya telephone + PC and the configuration the port is:
Interface FastEthernet0/16
description PHONE-DEVTORO-PC
switchport mode access
switchport port-security maximum 2
keepalive 4
Each time this port is down and the log say:
.Oct  2 19:03:23.559: %PM-4-ERR_DISABLE: psecure-violation error detected on Fa0/16, putting Fa0/16 in err-disable state
.Oct  2 19:03:23.568: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0027.0000.0000 on port FastEthernet0/16.
.Oct  2 19:03:23.568: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
.Oct  2 19:03:25.573: %LINK-3-UPDOWN: Interface FastEthernet0/16, changed state to down
I cant understand why this port is down, if only 2 devices ar connected to this por (Avaya Telephone and 1 PC), please how I can solucionated this issue. Thank you
David Chavarria
Wilson Bonilla
Level 3
Level 3
Hello David.
Based on the logs, the mac address 00.27.00 belongs to Shenzhen Siglent Technology Co..
Did you check the physical connections? please verify it's in deed just a ip phone and PC daisy chain connected.
Please post the output of the command
Show port-security interface fa0/16.
Can you disconnect the PC and run the command Show mac address-table interface Fa0/16, share the output.
Regards.
Wilson B.
Jaime Gonzalez
The phone boots on the DATA vlan and the VOICE vlan.
MAC security need to be set to allow MAX 3 addresss or more.
