2960 Lan Based routing
sejamc71
Level 3
Level 3
Former network tech deployed 2960 switches and left everything on VLAN 1. These are very remote so no hands on. I am wondering if I can change the SDM and enable LAN-Based routing so that I can create an SVI which will let me remotely manage to switch so that I can change VLAN 1 and setup a proper management VLAN without loosing connection to the switch. Has anyone ever done that? Currently, the management is on VLAN 1 so if I change anything, I loose connectivity. Setting up an additional VLAN with LAN Based routing on the 2960 switch would allow me connectivity to readdress the switch, correct?
Reza Sharifi
If this is an old 2960, they only support one vlan and that is for management. The newer 2960s and X series support multiple vlans depending on the license.
Martin L
most likely c2960 are only l2 switches with just 1 SVI. no routing. if yo have newer model , i think call 2960-X, you may enable more then 1 SVI. Still, those are not design for havey routing. Compare them to 3850 which can be l2 or l3 switches
Yep, that is what I am afraid of. I'm doing a ton of digging. These switches are about 800 miles away and were, prior to me, deployed without a separate management vlan, meaning user data and management on VLAN 1 with VLAN 1 being native. Now they want to introduce additional Subnets
I have physically lab'd this up exactly and here is the problem.....The Class C setup for production has been filled so I've created 2 new Subnets on their router as subinterfaces to gi0/1 (gi0/1.500 & gi0/.501) They can pass traffic on VLAN 500/501, but if a device with a VLAN5xx address is on the switch and the switch port is in a trunk configuration, it is not able to ping the gateway of VLAN 500 or 501. If I move the port to access mode with access to VLAN 500 or 501, it is then able to ping the applicable gateway.
Locally, if I make a separate management VLAN, assigned the current IP to a different vlan, I can then pass traffic to the existing subnet, VLAN 500 % VLAN 501 without issues. But, with management and data being on the existing VLAN 1, I can't do this as I lose connectivity to the switch because it resides on the subnet I have to change.  Anyone have any ideas how to do this remotely on a L2, lanbase device?
