2960 Physical Stack Cable Connection
jbuteau
I am connecting 2 ws-c2960s-48fps-l. I found documentation for connecting 3 or more switches for maximum redundency, but nothing for only 2 switches. Do I:
A) connect Master Stack Port 1 --> Member Stack Port 1
                 Master Stack Port 2 --> Member Stack Port 2
or B) connect Master Stack Port 1 --> Member Stack Port 2
                     Master Stack Port 2 --> Member Stack Port1
or Does it matter?
Thank you,
Jon
Daniel Hunter
Fairly sure it doesn't matter but I do recall seeing it documented as option B
Additional info:
Have a look at figure 5.1 (Working on the assumption that the 3750 stacking is the same as the 2960)
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_35_se/configuration/guide/swstack.html
Marvin Rhoads
I don't think it matters either in a 2-switch stack.
For what it's worth, there's a 2-switch example shown on page 23 of the Getting Started Guide that shows option A.
All of the other references I found show 3 or 4 switch stacks with something more akin to option B.
