2960-S switch firmware upgrade path ?
pfrancis3
Hello, I have a stack of three 2960-S switches. They are currently running ' Version 12.2(53)SE2, RELEASE SOFTWARE (fc3'.
Is it OK to do a direct upgrade to 'c2960s-universalk9-tar.122-58.SE2' ? or is an incremental upgrade required ?
I understand I simply upgrade this to the master switch in the stack and it then propagates to the other switches.
Is there anything else important I need to be aware of ?
Thanks for any advice.
jj27
You can upgrade directly to that version of code.  Just be sure to use the archive download-sw command and it will transfer the image to all switches in the stack.  Good luck!
