IPSEC vpn tunnel problem
triden001
I've got a Cisco 2851 router with an IPSEC split tunnel for clients to connect to using Cisco VPN client. We are we are encountering some connectivity issues with the tunnel that is reproduceable. First time connecting works fine for a few minutes, but then the connection refuses to transfer data and devices on the internal side of the tunnel are not pingable. Disconnecting, reconnecting and rebooting the PC does not work. Any idea's?
! Last configuration change at 11:31:22 PST Sun Mar 15 2015 by cisco
! NVRAM config last updated at 15:02:01 PST Fri Mar 13 2015 by cbeharrell
version 15.1
hostname gateway
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login vpn_xauth_ml_1 local
aaa authentication login sslvpn local
aaa authorization network vpn_group_ml_1 local
aaa session-id common
clock timezone PST -8 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.2.1 192.168.2.99
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.3.1 192.168.3.99
ip dhcp pool data
   import all
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 192.168.2.1
   domain-name icieng.local
ip dhcp pool guest_wifi
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 64.59.168.13 64.59.168.15
ip dhcp pool voip
   import all
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   dns-server 192.168.3.1
ip domain name icibbb.local
ip host w3.icibbb.com 192.168.21.200
ip host gateway.icibbb.local 192.168.2.1
ip host ucm.icibbb.local 192.168.2.99
ip host sw1.icibbb.local 192.168.2.98
ip host fs1.icibbb.local 192.168.2.97
ip host projector.icibbb.local 192.168.2.30
ip host pr1.icibbb.local 192.168.2.25
ip name-server 64.59.168.13
ip name-server 64.59.168.15
ip inspect name FIREWALL_OUT ftp
ip inspect name FIREWALL_OUT h323
ip inspect name FIREWALL_OUT netshow
ip inspect name FIREWALL_OUT rcmd
ip inspect name FIREWALL_OUT realaudio
ip inspect name FIREWALL_OUT rtsp
ip inspect name FIREWALL_OUT sqlnet
ip inspect name FIREWALL_OUT tcp
ip inspect name FIREWALL_OUT udp
ip inspect name FIREWALL_OUT vdolive
ip inspect name FIREWALL_OUT icmp
ip inspect name FIREWALL_OUT smtp
ip inspect name FIREWALL_OUT dns
ip inspect name FIREWALL_OUT https
ip inspect name FIREWALL_OUT imap
ip inspect name FIREWALL_OUT pop3
ip inspect name FIREWALL_OUT tftp
no ipv6 cef
voice-card 0
crypto pki trustpoint TP-self-signed-1619806428
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1619806454
 revocation-check none
crypto pki certificate chain TP-self-signed-1619806428
 certificate self-signed 01
  ***removed***
  quit
license udi pid CISCO2851 sn FHK110
archive
 log config
  hidekeys
username andrew privilege 15 secret 5
redundancy
ip ssh version 2
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp policy 2
 encr 3des
 hash md5
 group 2
crypto isakmp client configuration group ICI_VPN
 key icih78
 dns 192.168.2.1
 domain icibbb.local
 pool ici_vpn
 acl VPN_SPLIT_TUNNEL
 max-users 20
 netmask 255.255.255.0
crypto isakmp profile vpn-ike-profile-1
   match identity group ICI_VPN
   client authentication list vpn_xauth_ml_1
   isakmp authorization list vpn_group_ml_1
   client configuration address respond
   virtual-template 2
crypto ipsec transform-set encrypt-method-1 esp-3des esp-sha-hmac
crypto ipsec profile VPN_Profile_1
 set transform-set encrypt-method-1
interface Loopback0
 ip address 192.168.4.1 255.255.255.0
interface GigabitEthernet0/0
 ip address 184.62.99.250 255.255.255.252
 ip nat outside
 ip inspect FIREWALL_OUT out
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description DMZ
 ip address 192.168.21.1 255.255.255.0
 ip access-group DMZ_ACL in
 ip nat inside
 duplex auto
 speed auto
interface FastEthernet0/1/0
 switchport mode trunk
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Virtual-Template1
interface Virtual-Template2 type tunnel
 ip unnumbered GigabitEthernet0/0
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile VPN_Profile_1
interface Vlan1
 description data_vlan
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
interface Vlan2
 description voip_vlan
 ip address 192.168.3.1 255.255.255.0
 ip nat inside
interface Vlan4
 description guest_vlan
 ip address 192.168.10.1 255.255.255.0
 ip access-group GUEST_WIFI_ACL in
 ip nat inside
ip local pool ici_vpn 192.168.2.200 192.168.2.209
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip dns server
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.21.200 8090 184.62.99.250 8090 extendable
ip nat inside source static tcp 192.168.21.200 8443 184.62.99.250 8443 extendable
ip route 0.0.0.0 0.0.0.0 184.62.99.249
ip access-list extended DMZ_ACL
 permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended GUEST_WIFI_ACL
 deny   ip 192.168.10.0 0.0.0.255 192.168.2.0 0.0.0.255
 deny   ip 192.168.10.0 0.0.0.255 192.168.3.0 0.0.0.255
 permit ip any any
ip access-list extended NAT
 deny   ip any 192.168.0.0 0.0.255.255
ip access-list extended VPN_SPLIT_TUNNEL
logging esm config
control-plane
mgcp profile default
telephony-service
 ip source-address 192.168.0.6 port 2000
 application telephony-service
 max-conferences 8 gain -6
 web admin system name admin password admin
 transfer-system full-consult
line con 0
 logging synchronous
line aux 0
line vty 0 4
 exec-timeout 15 0
 logging synchronous
 transport input ssh
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server 1.ca.pool.ntp.org
ntp server 2.ca.pool.ntp.org
ntp server 3.ca.pool.ntp.org
end
triden001
any ideas?
