12-12-2011
12:45 AM
- last edited on
03-25-2019
04:17 PM
by
ciscomoderator
Hello everyone,
I have a design for my infrastructure and i'm thinking to choose 4 or 5, or more, 2960 series in a stack mode instead of one 4500 series?
Please can someone tell me what design is better and why?
Thank you for your advise.
12-12-2011 12:59 AM
Dear
If you r using 2960 in stack mode , then you have available bandwith in stack port is 16gbps(switch to switch bandwidth), its better if you are using 4500 only for more bandwidth.
but if you need hardware redundancy then you can use 2960 in stack mode.
Thanks.
Debabrata Das
12-12-2011 01:05 AM
Hi Dear,
thank for your quick repply.
You are right concerning the redundancing in hardware with stack mode and the througput in stack port.
But is it any other fact to take in consideration? when choosing one of both design?
Tks
12-12-2011 01:31 AM
Dear .
I think its better if you are using 2960 because 16gbps is not matter of jockes, and also u have a another facilities to using hardware redundancy.
so my suggestion is to use 2960...
Debabrata Das
12-12-2011 03:52 AM
Thanks Dear,
On that point your are right. but if my throughput needed between switches are more or around 16 Gbps?
Please how can i check the live throughput on the switch?
With #show interfaces
and looking on:
5 minute input rate 97000 bits/sec, 9 packets/sec
5 minute output rate 50000 bits/sec, 61 packets/sec
Tks
12-12-2011 04:18 AM
Dear,
Also, what about the backplane or control plane in the two design?
Tks
12-12-2011 12:02 PM
Duplicate post:
